DMF
threepot
DMF
Post by threepot »
Hi guys,new on here ok. May be buying 406 hdi,2l estate,reg march 1999. Clutch slipping. Can you tell by the reg date if it has a DMF? Thanks
joethefish
Re: DMF
Post by joethefish »
Is it a 90 or 110 hdi?
threepot
Re: DMF
Post by threepot »
110 i think
Re: DMF
110's have an intercooler, (to the right of the radiator, looking at the front of the car), 90's don't have an intercooler, (or a DMF).
Assuming it's a 110, It's likely, (but not certain) to have a DMF. Most do, but some of the early examples didn't. It's also possible someone has already converted it to solid flywheel.....
Your best bet is to establish availability for either option before stripping it down.
plod
Re: DMF
Post by plod »
I have a Jan 99 HDi 110 and that has a solid flywheel as standard
Maybe someone could check on servicebox if we had your vin
1999 D8.5 HDi GLX - Sold :(
Re: DMF
Unless it's slipping badly (and all the time) you have got plenty of time to get something sorted if you like the car in general - and it'll give you bargaining power in the deal.
Mine used to slip when the engine/trans got hot (after an hour or so) where it would 'blip' on the rev counter under load (approx 2000 rpm) and then catch up with itself.
A solid conversion is probably the most reliable and cheapest option but also check and replace the main engine mounts for best performance.
Re: DMF
plod wrote:I have a Jan 99 HDi 110 and that has a solid flywheel as standard
Interesting :? I've just been looking in (the wonderful :roll: ) Service Box, D8 DW10ATEDs had a solid flywheel while D9 ones had DMFs. Allegedly.
It *should* be up to chassis VF38?RH??8080000 is a solid flywheel, after that is a DMF. I'm also wondering about the RHS/RHZ thing, how does this compare to yours?
plod
Re: DMF
Post by plod »
My chassis is VF38BRHZE80699***
threepot
Re: DMF
Post by threepot »
Waiting for vin. I bought this car on ebay..£375.red estate 1999 on a t. 114k. Some of you may have seen it? He tells me clutch not slipping that bad?? Worth a chance for the money i think? I spoke to a local pug specialist,he,s 90% sure its a solid f/wheel?
Thanks for all your input guys.
Re: DMF
Not abad price that mate,
iweighed one in and got £350 for it so at £375 bargain,
even if it does have Dmf, id just change the plate, theres not much mention of Dmfs failing on pugs,
ive not seen one with a failed dmf, unlike ford etc, there prone,
threepot
Re: DMF
Post by threepot »
You mean just the friction plate? Seen them on ebay , about £80? My Local garage chuarge about £200 labour.
Re: DMF
Yup clutch /friction plate,
£80? you wouid get one alot cheaper than that, im sure,
plod
Re: DMF
Post by plod »
I paid about £145ish for the 3 piece clutch, 2 litres of gearbox oil, and a bottom engine mount and that was from the stealer !!!!!
threepot
Re: DMF
Post by threepot »
Hi all. Picked car up earlier. Drives really nice for 148k. Steering,box,feel good.Good engine,no smoke,starts nice. Quiet too,and smooth. Bloody nice car actually. Clutch is slipping tho,but it got me home. Used just over £20 diesel to cover 150mls..not bad eh considering clutch slip.My dad had the petrol estate on a Y,says it was one of the nicest cars he'd owned. Anyway,got the vin..vf38erhze80727994. Hope one of you can tell what flywheel?? Cheers.
Re: DMF
Service Box wrote:VIN Invalid
Think you might have missed a digit?
