Exhaust 110 fitting 90?
pfusi1
Post by pfusi1 »
I've got a goer of a HDI 90 estate with a shagged exhaust (bar back box) and a very good exhaust on a scrap HDI 110 estate (bar back box).
Was hoping to take the good back box off my car and put it on the good exhaust from the 110 car, but the 110 exhaust seems to be three sections with a centre box, whilst my 90 exhaust only has two sections and no centre box - would this be a feasible option?
Other than that will be changing over wing, front doors, alloys, bonnet and 7-seat conversion to make my car look top dollar! Just changed the font drop links, both track rod ends, new n/s driveshaft (I got it so cheap it was less than replacing the gaitors) and both lower ball joints (copper greased them to f*ck on reassembly). Also new disc and pads front and rear but have still to change the rear links (both metal and plastic ones each side) to hopefully stop the rather unnerving rear steer effect I'm getting occassionally!
Also, does anyone know a decent place to buy a new primer bulb, I'm getting air in the clear fuel lines and I'm fairly certain it's the primer bulb at fault - new fuel filter and seal hasn't cured the problem (not that pressing down on the lid of the fuel filter got rid of the bubbles anyway). Finally getting this car sorted to be a bit of a peach and might end up having a company car soon - feel quite sad about it.
Re: Exhaust 110 fitting 90?
Hi . As far as ican see,
the 90bhp and 110bhp ( Egzhaust ) shouid fit either,
there both, 2.0s
perhaps what youve noticed is one has a cat and the other dosent,
id just swap the full exhaust over,
The back boxes look the same but have different part numbers so I reckon you'll have to suck it and see.
The primer bulb comes with the fuel line and is 16-17 quid :roll: I'm not sure if you can get one from a factor, maybe some sort of universal one but then it'll have joins which will introduce more possibility for air leaks :frown: They're a very common part across Citroen/Pug for cars with the HDi 90 Semen's so possibly second hand?
rwb
Post by rwb »
Are you seeing bubbles in the clear plastic tubes that go to/from the fuel filter?
Apparently this is normal.
Or are there more serious symptoms?
omega
Post by omega »
rwb wrote:Are you seeing bubbles in the clear plastic tubes that go to/from the fuel filter?
my 2.1 has had bubbles in the line for the past 5 years ive had it
