There are a number of threads where people have upgraded their 406's with dimmable mirror. However, it seems as though most or all of these do not have automatic wipers already. My car does - and I don't see a cut-out in the black windscreen cover that could fit yet another sensor. Is it the same sensor that is used both for wipers and the mirror? Does the sensor have additional pin-outs where the mirror can be connected?
What about the reverse-wire, is it unlikely that it is present? If so, how have the rest of you routed it?
Once I start I'll try to keep this thread updated with what I learn along the way.
[SOLVED] Dimming mirror, existing rain sensor
Re: Dimming mirror, existing rain sensor
Hi,
as much as ican Remeber, There was only Member" Him big cheif that Retrofitted the Dimming mirror, iirc he used a Laguna one, imight be wrong on that tho,
Himbigcheif as not been on the Forum in a while, shame realy as he wouid be the Best person to ask on how to fit one,
There are 406 ones floating around but theyre expensive, one here Ebay link as you will see Pricey, http://www.ebay.co.uk/itm/PEUGEOT-406-E ... 3cc5594e97
Im looking into fitting one,but not on a 406 Alaguna, as far as ican see you just use a feed from the Light to get one up and running,
Chances are it'll be a right pain to get the reverse wire routed, and it's really not worth it given how slowly the mirror reacts - just switch the thing off before trying to reverse
Reverse wire?
sorry lost me there,
3 pins on the connector - +12v, ground, and a wire indirectly connected to the reverse light switch on the gearbox. When there's 12v on this wire (ie when you're reversing), the mirror un-dims.
Ah rite,
thanks for the info
thanks for the info
i've fitted a laguna/megane one with no problems at all ... just connected to the light of cigar lighter, so when i turn on the lights it will turn on the mirror.
edit : Initially i used the 406 mirror mounting, you will need to do a hole to pass throw the wires(it is a bit strange because the mounting is black and mirror beige ) so then i moded the laguna one, and now it's with the laguna's.
Can take pictures if you want.
edit 2:
only con about using the laguna's:
Here when i have the chance, i'll try to paint the windscreen with something black on the interior....
now the interior:
Now in the next picture, if you notice closely the superior part will need to be sanded, but i sanded a bit too much on mine, but not so ugly.
edit 2:
now the interior:
Re: [SOLVED] Dimming mirror, existing rain sensor
That was easy!! Clipped the old mirror off by pushing forward (in the direction of the car) parallel to the windscreen until it released (same approach as this video). Tucked away next to the rain sensor itself was an original connector for the mirror, wrapped in what is now 15 year old masking tape (sticky, yucky!). Removed the tape, tried to remove some of the residue with isopropanol, and connected the replacement mirror. The replacement mirror was then clipped back on.
Mirror tested, and found to be working!
