Sorry to keep posting about my heater fan, but ive replaced the resistor (twice )(ebay seller agreed it was faulty) but now instead of running flat out as before now the fan is idling slowly as soon as the engine is started (which i think is normal) ie it never actually switches right off? The speed control on dash only increases the speed one notch and when I go to full speed on the control switch it stops completly? all the heater temp and aircon are working just a slow fan does anyone think it could be yet another resistor failure or motor problem?
Any help appreciated as the weather is getting hot and I can't force much cooled air into cabin.
The car is a D8 body but a 2.0 Hdi engine exec estate regd 25.03.1999
heater fan
Re: heater fan
When my fan resistor went south the fan would idle all the time and when i set to flat out it would momentarily go fast then stop altogether then after a while start again but would just keep stopping when it felt like it,with the new resistor (from GSF) it idles all the time which i think is normal and all the other speeds are o.k. now,sounds like you've still got a duff resisitor to me.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: heater fan
i just had to replace my resistor m8,got mine of ebay,brand new for 30 quid works great but i also had to wire mine direct to the battery as there was no power getting to it,did u buy a new resistor or second hand [email protected],this is where i got mine m8,if its any help to you,they give a years garentee as well,just thought,mines an 02 2.0hdi.
Re: heater fan
Hi both, thanks for the replies. I also got mine from MHK and am getting these problems with both units which they exchanged the first one with no argument. As you have had good service from them I begin to think I have another problem (but really not sure) Maybe Ill try to get another complete motor off the forum if anyone is breaking an early 406 with climate.
Kind regards Keith.
Kind regards Keith.
Re: heater fan
my 406's fan stops sometimes on full. if i just touch the slider slightly it comes back on. i think they all do this.
have u tried flicking it when it stops at full ?
Re: heater fan
also my fan is spinning even on lowest setting. this is normal im sure.
i had a guy viviit me a few months ago to buy the fan and when he plugged it in it was spinning even when the slider was all way left.
Re: heater fan
Hi, I thought the fan ran slowly all the time so that verifies that, but I dont have a slider its a square rocker switch and I get a series of lengthening vertical lines in the display relative to the fan speed
Re: heater fan
ah right i see. im not familiar with the digital ones sorry i carnt help .
