Just come back after a 1500 trip, now the car has been standing for a couple of hours and I have noticed that on the drivers side there are two puddles one under the sill near the front wheel and another just before the rear wheel. I searched on the forum and found a couple of posts about the sill drain holes, checked and they are blocked. Now the questions, the car is parked on a slight (and I mean slight) hill nose up, when I tried to unblock the rear I got lots of brown rust "dirt" but not a lot of water just a slow rate of drips, I did the front and got a stream straight away with not rust at all, does anybody have any ideals how I can clean the rear hole out?
Also the sill seal is spilt at the drivers door and the door seal is missing a strip halfway down the pillar. Am I right is thinking this will be the cause?
And last of all anybody got the part numbers and cost of these two seal so I can get a replacement tomorrow. PS its a d8 estate if thats any help.
Thanks for any help you can give.
Thank you and a question
Re: Thank you and a question
I just used a No.1 screwdriver
Split seal is the likely cause, especially if there's clips missing (i.e. holes leading straight into your sill-mounted aquarium).
Umm, part numbers, umm...
Dammit, I'll have to log into Windows for the password
Back again (I must remember to copy over the passwords I don't know...)
Left: 9023LJ
Right: 9023LK
26.58 each (how much?!!
Clips: 699786 You need 11 a side and they+re 7 pence a pop.
Btw the seals are the same saloon & estate, D8 & D9
Left: 9023LJ
Right: 9023LK
Thank you that's great, off to the sealers tomorrow.
