i think i m have lost my marbles just purchased a laguna 1.9 dci initiale its only now that i am reading about the turbo and electrical problems
does anyone on here know anything bout them
help
Re: help
Reading about them here or elsewhere? There's been a few discussions on here about that very car, have a search if you aint already- I reckon Lozz is your man
Is it me or is Renault the reason French cars have such a bad rep?
- sirwiggum
Re: help
Lozz is yer man for sure.
I agree, when I had Citroens and the Pug, people used to say things like "*suck air through teeth* I had a Renault 18 back in the day. Bag of bolts. Thats why I only buy 316is now. On which the turbo and clutch have went prematurely. But thats typical German efficiency. Replace early, replace often, keep it new."
Re: help
What do you need to know mate,?john170277 wrote:i think i m have lost my marbles just purchased a laguna 1.9 dci initiale its only now that i am reading about the turbo and electrical problems
You will here loads of horror stories about them, Turbos being weak, idont think thats the case, as the lag as the same turbo as Mitsubish and the volvo s40
if they was weak they wouid be on the horror story list too me thinks,
ithink its all down to using the right oil, and changing it reguarly, (iuse 5w /40)
electrical problems, thats mainly down to them getting Drenched, if iwas you when you get a dry day, clear out the scuttle drains, you dont have to remove half the car as it says in the haynes, just take the plastic caps off and get something in there to clear the drains iused an old wiperblade, ive not seen one yet that hasnt been full of leaves, also clear off pollen filter,
if left blocked water ends up in drivers foot well -frys the bsi /fuse box http://www.renaultforums.co.uk/showthre ... tle+drains
ive had mine a few months now and not had any problems with it, other than a weak spring, blocked pollen filter, and a rear wheel bearing,
if youve got the pk6 gearbox they can be abit iffy, (weak boxes idont know
mines been ripped out at one stage and replaced with the 5 speed. http://www.renaultforums.co.uk/showthread.php?t=40144
Another tip: if you hear a buzzing noise in the engine bay, get a peice of carboard and slot it in between the Maf and the fuse box,
the noise will disapear, the maf vibrates against the fuse box on them,
Another thing: pop the cover off the passenger front door handle and spray the lock with wd40 mine was seized and iwanted it working just incase key card didnt work or if battery goes flat etc,
Re: help
Horror stories can put you off anything you buy, in the past i've not bothered with car forums not until i googled the 406 and some things you read make you think what the hell have i done? it's not just cars i bought a tent last week then the mrs read some reviews saying their a nightmare to get the clips into the poles so i was worried i'd rip something erecting it.... It took me 20 minutes and the clips went in easy.
Dont believe all you read if you have a problem with the car ask about it then and you should get a well informed answer.
Re: help
W'ell ihad aplan but its gone all 'pear-shaped.
abeit like thems. Asda cheap kettles or toasters, buy 2. if one blows up youve got aspare one,
altho it seems the lag as Rocketed up abit in price, carnt find a cheap one, for spares
Re: help
Ive been speaking with a Renault mechanic,
asked him about the renault turbo problems,
and got an honest enought answer,
it seems theres a Desighn flaw, Namely this item,
http://www.ebay.co.uk/itm/Renault-Lagun ... 2a1c586859
(* ive used the ebay link for refernce of the picture of the item- not the infomation,)
if anyone gets a laguna or anything with this dci lump
and its low on oil and you top it up, Automaticly you will think just top it up like and other car and just drive it Wrong!
if you top the oil up dont drive the car or even start it for atleast half an hour, you have to wait for the oil to flow through and level off,
totaly daft desighn
totaly daft desighn
