Idle adjustment on 1.9 dt
Old Smokey
Post by Old Smokey »
Hi everybody, this is my first post !
Does anyone have a photo of the Bosch fuel pump & what the relevant adjustment screws are ? I need to adjust my idle, running too high 1200...
Can anybody help as i,m not sure exactly what to adjust. My engine is 1900 turbo diesel
Cheers Ian :?
=Arial] [/font][font=Arial] [/font][font=Arial Black] [/font]
Hello Smokey :cheesy:
If I remember, the high idle is down to something else, and not just a case of 'turning it down'.
Try a search on here, but also others on here will know who have had similar problems, someone will be along soon...........
jameslxdt
Post by jameslxdt »
where the top intercooler hose is theres a metal bracket with a vacuum servo attached, theres a cold idle cable on it, facing the car pull it too the right, with the engine once up to 80 degrees, if the idle goes down you need to adjust the cable, i think theres 2 10mm nuts
