front struts
snakemaster
front struts
Post by snakemaster »
i have seen some clamp that has a lip on it so it stops the spring sliping off if the spring brakes , it bolts to the bottom of the spring plate , can you get them on the later 406s ?, or what other car would you get them off , and i can will pick up a pair from the scrapys cheers
Re: front struts
ive never seen them on 406s ,
astrut itook of a renault had one on but it looks like it was Welded ..most probs an uprated unit,
it be something id be buying if there available tho,
if you see out please post a link
