How many radiator bleed screws on D8 SRI?
jason1987
Post by jason1987 »
i need to fill my coolin system with anti freeze soon (just water in atm), last time i did it i could only find 2 bleed screws, reason i ask is im on my 2nd heater matrix, last one leaked again but think it was due to the coolant cap being jammed and not releasing pressure, have now got a new cap, just wanna make sure im not missing a bleed screw and it happening again.
the bleed screws i found were on the thermostat and by the bulkhead on heater pipe i think
Re: How many radiator bleed screws on D8 SRI?
I'd expect another on the top rear of the radiator, the 2.1 td had one (along with perished washer) and so does the HDi. Unless it's a moody rad of course.
If memory serves (it was a long time ago when I had an XU10J2TE and changed its thermostat), there's just the two which you've found.
mjb wrote:If memory serves (it was a long time ago when I had an XU10J2TE and changed its thermostat), there's just the two which you've found.
Yep, spot on.
