Hi all,
The heated seats on my 96 406 Executive don't work. I've checked the main fuse box and that's fine. Any ideas?
Heated seats
Re: Heated seats
Undo the plug under the seats and check there's 12V present when the engine's running and the switches are engaged.
It's not unknown for the actual elements to fail, and these are a total pain to replace!
Re: Heated seats
jonsowman wrote:Undo the plug under the seats and check there's 12V present when the engine's running and the switches are engaged.
I'm guessing it's not the elements as both heated seats are not working. Unless it's some cunning French coincidence.
The switch lights up when they're on, if that helps.
Re: Heated seats
Check for voltage at the seat connectors.
straggler wrote:I'm guessing it's not the elements as both heated seats are not working.
I wouldn't bank on it...straggler wrote:96
Re: Heated seats
The lights on the switches are separate to the actual heater supply (switch is double pole, single throw), so just because the lights are on does not mean there's a complete circuit through the heating element
Edit: Speaking of which, when you've got the plugs out, measure the resistance across the heating elements with a multimeter. Should be a few Ohms. More than 10 means they're broken.
Re: Heated seats
Thanks for the replies. I'll have a poke about under the seats and see what happens.
Is all that gubbins under the passenger seat to do with the heated seats?
Re: Heated seats
I have heated seats in my executive, which up until Friday never worked since I've owned the car. Lights came on but no heat. The passenger seat had a broken wire which was very easy to fix as it was at the very start of the wiring that goes up into the back of the seat. The driver side was a bit different. I had to completely remove the leather that covers the seat so I could look at the heat pad itself. No broken wires this time, but a faulty thermal switch. It basicly pops when a certain temperature is reached which cuts power to the circuit. Hope you get yours sorted before the big freeze hits.
