Not sure if this is the right section, but never mind. I'm struggling with the door locks on my D8. I've had a quick search and it seems a few people have had similar issues. Gremlins are:
Central locking motor doesn't work on the drivers door - not normally a problem as I unlock that door with the key.
When unlocked with the key, drivers door makes a click click click noise after all the other doors have finished unlocking.
The lock on the drivers door has gone really stiff. Lots of wiggling needed to get it to work - more often than not it spins in the barrel (anti theft I believe)
My boot lock has seized solid, but still works on the central locking.
Remote part of the central locking doesn't work. I got a new battery for the key when I bought the car and spent ages trying to get it to sync back up with the car. It would only ever operate when I was sat inside, which kind of defeated the point of remote locking. Shortly after fitting, the light on the key gave up working when I pressed the button - perhaps a dodgy battery (it was from flebay)?
So, I'm a little worried the drivers lock is going to give up completely and I'll be left climbing in through the passenger door
I'm presuming the best solution might be to replace the lot, but I'm not sure I fancy all the pain of swapping everything over.
Thanks in advance!!!
