AUX DRIVE BELT CHANGE
need help drive belt on my 406 2.0 hdi not sure if it 90 or 110 but gt new belt 6pk1753 its the one with pas pump at top came off any diagrams or exact fitting guides an advantage dnt wanna mess it up oh it has a/c cheers guys
Les medecins choisissent www.viagrasansordonnancefr.com traitement efficace
Re: AUX DRIVE BELT CHANGE
yep the belt is the right lenth
to change the pelt theirs a black pulley down the side of the engine on that pulley is a 15mm hex head with a ring spanner lever it back and slide a 4mm pin in the holes on the back of the idler the belt is now loose and you can take the belt off
to put the belt back on you may need an 8mm hex key and a 1/4" drive t bar this is from adjusting belt tensioner to get to this you may have to remove the drivers side wheel and arch liner
loop it over the ps pump then round the tensioner then the alternator down to the a/c pump then the crank pulley and it should be under the spring loaded idler
that should do it, have a look in the knowledge base there may be a guide
and check all the pulleys and idlers for play
- lozz
Hi and welcome on in mate
Have a watch of Farmer p's video
http://www.youtube.com/watch?v=XDTot5kRAG0
Dnt have a 15mm spanner will a socket do it
All fitted not sure if a pulley on its way or belt too long but won't sit on the power steering pully properly keeps coming off a little
- lozz
Hi,
it couid be the Excentric pulley needs adjusting,
Carnt see it being the wrong belt, normaly the belt wouid be too short if its the wrong one,
Success no more jumping off turns out with the shorter belt I wAs over adjusting it
