BabyBoomer47
Posts: 4 Joined: Thu Mar 29, 2012 8:47 pm
Post
by BabyBoomer47 » Sun Jan 27, 2013 11:13 pm
I have a late 03 plate HDi 90 Rapier and wondered if its possible to fit the Pug Cruise Control unit as fitted to some 406 models, anyone have any ideas?
RobTurbo
Posts: 137 Joined: Sun Jun 24, 2012 10:43 pm
Post
by RobTurbo » Sun Jan 27, 2013 11:48 pm
You need an extra brake switch, it goes next to the one that's already there, you can use a clutch switch if you cut the keyway out of the connector, and the cruise control stalk, then turn it on with pp2000.
Posts: 10710 Joined: Mon Oct 13, 2008 11:49 pm
Post
by Doggy » Mon Jan 28, 2013 8:14 pm
An 03 HDi 90 is likley to have a Siemens ecu, which isn't going to support cruise IIRC, (didn't Bailles try some time ago)?
2003 HDi 2.2 6 -speed Exec Estate (2012-19) (also a gem)
RobTurbo
Post
by RobTurbo » Mon Jan 28, 2013 8:34 pm
Mine is siemens as well and I managed it!
Post
by Doggy » Mon Jan 28, 2013 9:15 pm
Good for you - was it just a question of enabling the function, (as in a Bosch EDC15), or did you have to employ a bit more sorcery?
RobTurbo
Post
by RobTurbo » Mon Jan 28, 2013 9:19 pm
It just needed enabling in the ecu and bsi, no fancy jiggery pokery required!
Post
by Doggy » Mon Jan 28, 2013 9:23 pm
Interesting and good to know for future reference, much appreciated.
