radio codes
radio codes
hi to all . just registered as a new member, having recently obtained a p reg 2.0lx saloon in lovely condition with only 47500 miles under her belt, i am very happy with the car quiet and comfortable , unfortunately there is no note of the radio code in any of the manuals , the model is 22dc 594/65 no phapbft9042240, any help would be very much appreciated, thanks in advance for any replys
Re: radio codes
pull the radio out and have alook see if some ones wrote it on the lid
sometimes you can get lucky and it will be written on in marker pen,
My internet is down atm,so icarnt look for a code calculator,
hopefully someone else on the forum might have one,
Re: radio codes
Ill have a look for you
Re: radio codes
Hi, I read on another forum that Peugeot use a "1234" system.
This basically means to look at the last 4 digits on the serial number and add 1234 i.e if the last digits are 3472 then add 1 to the first number, 2 to the second, 3 to the third and 4 to the forth. This would make the code 4,6,10,6. If any one of the numbers is more than a 6 - the 10 as digit 3, then subtract 6. Code would be 4646. If you can't get the code in, hold the band or ~ button for 15 secs. to clear system.
Tried it on a 306 and it worked. Could always Google this for a better explaination.....
