Now then,
Adding to my current wiper prob (which I hope is just the motor...)
I'm havin probs with the central locking. The remotes never work due to not havin a circuit board in it, I'm told its about £170 from peugeot for a new remote and it has to be programmed (mines an x-reg 2000)
Anyway I've always locked with the key and i've always had problems with the passenger door but would just lock/unlock from the inside. Problem now is it only unlocks the one door, i've looked about on here and seen references to the fuse on the bsi A port 20amp, just had a quick look in the dark and it looks ok.
If it aint the fuse is their another problem that I can look at?
Central locking problems
Re: Central locking problems
I use these people for key fob repairs, very good service with no hassle......
http://www.ebay.co.uk/itm/Peugeot-406-1 ... OC:GB:3160
Just to add to Jaspers post, i've used them to and they're good.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
To add an update on this problem,
I can no longer get into the back, both doors won't open. Even if I unlock them from the inside they won't open.
Does this sound like a partially fault?
I've heard rumours that its the central lockcing unit in the boot? But I've also been told its in the door?
Someones else has also told me could be a Comm2000 problem but I aint a clue..
the central locking unit is part of the bsi unit,sounds like a wiring problem or the solenoids in the doors.Do the front doors work on the central locking?
no. only the door the key is in will open.
The passenger door use to bounce back on locking tho.
I can still deadlock the boot tho but not the passenger door
