Speedo cuts out
Speedo cuts out
Twice this morning my Speedo cut out (dropped to 0) then cut in again dunno wats causing it no loss in power just seems like it switching itself off
Les medecins choisissent www.viagrasansordonnancefr.com traitement efficace
Re: Speedo cuts out
If there's no loss in power, the error is probably in the instrument cluster, not in the speedo sensor itself.
2000 406 TS4 2.2 saloon
- Tubthumper
Re: Speedo cuts out
Hi Mike,
I've had the same issue with my HDI 90 for almost a year now. I have changed the speedo sensor, and re-soldered the clocks to no avail, and now I also have a temp guage that drops to zero from time to time
My next step will be to replace the cluster, it's just finding one that's got the same or lower mileage than mine.
2000 HDI 90 Rapier estate.
