not sure if i got this under the right topic. but im after some help with my towbar fitting.
i have taken the towbar or my s reg estate to put on to my r reg estate. when taken off the old car the 4 bolts (2 either side) where bolted in to something. but when coming to fit it to my new car this morning the four bolts have nothing to bolt in to. the holes are there but no nut or therd to go in to. when i took it off the old car i did not see any bolts that fell out.
i have had a look to see if i can fit some nuts behind but there is no gap to fit a nut in.
im not sure if there is something missing or does any one have any ideas on how i can over come this please.
towbar help
towbar help
406 2.1 turbo diesel estate ( now scraped) have some parts
406 2.0 petrol estate
Re: towbar help
If its anything like my towbar which i replaced last year,there are retangle shaped wedges with nuts built into them which slot inside the chassis that then allow you to bolt the towbar in.If that makes sence.
2003 Hdi Est SE
Re: towbar help
i think i get what you mean thank you, i will have to have alook around for some as the old car has now gone. didnt think to look to see what held them in place lol
but thanks again
but thanks again
Re: towbar help
Its not these in the link as they are too square,but you will see what i am on about.
http://www.ebay.co.uk/itm/DEFENDER-SERI ... 33662da97c
2003 Hdi Est SE
Re: towbar help
perfect thank you for the link. i have a shop down the road to me that all sorts of fixtures and fittings. i shall go and see what they nhave. i take it it goes it to the square hole, has i have round holes and square holes
Re: towbar help
If the holes are next to each other then yes,the fixings go through the square holes,then the nuts should line up with the round holes and the towbar can be bolted on then.
2003 Hdi Est SE
Re: towbar help
if it's not those then their pretty damn close they look very much like the ones on mine.. probably just a different size?hammerman wrote:Its not these in the link as they are too square,but you will see what i am on about.http://www.ebay.co.uk/itm/DEFENDER-SERI ... 33662da97c
Re: towbar help
Except they're imperial - http://www.pegasusparts.co.uk/ourshop_9 ... inges.html
