FAO Ares
trem1
FAO Ares
Post by trem1 »
as requested this is the info from servicebox for you
Vehicle characteristics
Vehicle family 406
Build code 07345 89 3 0049
Warranty Start Date 01/01/1990
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE / COMPONENT TYPE PEUGEOT
FAMILY VEHICLE 406
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL LEVEL 3
ENGINE TURBO INJECTION XU10J2TE
TRANSMISSION BVM5
PAINT TYPE METALLIC Paintwork
BODY COLOUR EYC - QUARTZ GREY PAINT
INTERIOR TRIM TYPE DUNE VELVET "BM"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) BVM ML5T
ENGINE (TYPE) XU / XUD
OTHER BADGE WITHOUT FULLER BADGE
BADGE SV
TRIM LEVEL LEVEL 3
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 25X20
Fuel supply-Engine
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
SPEED SENSOR SIGNAL SENSOR INTERFACE +
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER MNTG WATER / OIL EXCHANGER ON ENGINE
FUEL TANK INSULATION FUEL TANK INTERIOR INSULATION
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
RHEOSTAT RHEOSTAT
FUEL VAPOUR RETRIEVAL PETROL VAPOUR RECOVERY CONTROLLED
INJECTION ASSOCIATED VARIANT W / O INJECTION VARIANT
Transmission Gearbox
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID gearset 16 X 69
WHEEL STYLE ALLOY WHEEL MISTRAL
CLUTCH HYDRAULIC CLUTCH
GEARBOX SAFETY LOCK W / OG / BOX SECURITY LOCKING
TYRE (SIZE, TYPE) 205X60X15 TYRES V
WHEELS FITTED 6.5 "RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
TYPE GEARBOX ML GEARBOX
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 22.5
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE COMPENSATOR WITH SLAVE
BRAKE TYPE VENTILATED FRONT DISC / REAR DISCS
POWER STEERING FLUID COOLING SYSTEM WITH COOLING
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
Body fittings
HORNS HORNS-HARMONY
AERIAL LONG ROOF AERIAL
WIPER ARM FRONT BLADE WITH DEFLECTOR
SIDE MOULDINGS (TYPE) PROTECTOR W / CHROME RING
WHEEL embellisher (STYLE) WITHOUT WHEEL CAP
SIDE REPEATER INDICATORS SIDE-FLASH UNIT ASSEMBLY
INDICATORS SIGNALING WITHOUT LIGHTS
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W / O ENGINE UNDERSHELDING
WASHER JET WINDSHIELD WASHER JET W / DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION FUNCTION WITHOUT FULLER
Tailpipe EXHAUST TRIM SINGLE OUTLET
ENGINE BAY soundproofing BONNET SOUND PROOFING-
WINDSCREEN GLASS (TYPE) NO HEATING WINDSCREEN
WINDSCREEN WIPER Intermittent AUTO FR WIPER BLADE
REAR SCREEN WIPER W / O REAR SCREEN WASH WIPE
HEADLAMP WIPER HEADLAMP WASHWIPE
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER WITHOUT BUMPERS embellisher
MUDFLAP WITHOUT MUDGUARD
LUGGAGE RACK ROOF BARS WITHOUT
FRONT Foglamp FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT RRVW EXT MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE MIRROR HEATED PASS RRVIEW ELEC CNTRL
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES DOOR HANDLES AND MIRROR BODY COLOUR
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) QUALITY LAMINATED 2
Interior fittings
REAR HEAD RESTRAINT REAR ADJUSTABLE HEADREST
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT REAR BENCH SEAT CUSHION SEPARATE SINGLE SEAT BACKS
SUPPLEMENTARY SEAT SEAT WITHOUT SUPPLEMENTARY POSITN
REAR SEAT ARMREST WITH REAR ARMREST
INTERIOR ALARM FORGET ALARM LIGHTS
RADIO TELEPHONE TELEPHONE EQUIPMENT WITHOUT PRE-
LUGGAGE COVER WITHOUT LUGGAGE COVER
FRONT seatbelt Pyrotechnic WITHOUT SEAT BELT ALARM
AIR CONDITIONING MANUAL CONTROL CAR HEATER
SPEED GRADUATIONS GRADUATION KMS / H
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL receiv FRT REAR SPEAKER SPEAKER TWT
CONSOLE LONG CONSOLE
DRIVING POSITION LEFT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
EQUIPMENT DASHBOARD LARGE GLOVE BOX COVER DASHBOARD, WOODEN TRIM
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM TRIM BOOT FLAP + RR TAILGAT
DOOR TRIM DECORATIVE WOOD TYPE
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT Anchoring POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER W / LOUDSPEAKERS
RADIO CONTROLS WITHOUT REMOTE RADIO CONTROL
POLLEN FILTER WITH POLLEN FILTER
SCREENING (BLIND SIDE SUNBLIND, SUNROOF) WITHOUT SCREEN SUN VISOR
DRIVER SEAT CONTROL FRT SEAT DRIVERS MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL FRT SEAT PASSENGER MANUAL CNTR
DRIVER SEAT ADJUSTMENT DRIVER'S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT TILTING BACK PASSENGER
INT. UPHOLSTERY ELEMENTS Weaved NOT TRIM ROOF
FRONT SEAT ARMREST FRONT ASSEMBLY WITHOUT ELBOW REST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
HandBrake WARNING LAMP PARKING BREAK WITHOUT INDICATOR
REAR WINDOW LIFT RR WINDOW LIFTER ELECT CONTR + LOCK SYSTEM
DRIVER'S WINDOW LIFT DRIVER'S ELECTRIC WINDOW SEQUENTIAL
PASSENGER'S WINDOW LIFT CNTRL ELEC WINDOW LIFTER FRONT PASS
DISPLAY DISPLAY (OR CLOCK AND TEMP)
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER + PASSENGER WITHOUT LIGHTING
OIL GAUGE OIL LEVEL INDICATOR STD
FITTING REAR HEAD RESTRAINT 2 REAR MOUNT HEAD-REST
HEATING ELEMENT HEATED SEAT
FRONT SIDE AIRBAG WITHOUT SIDE FRONT AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVER + PASSENGER ELECTRIC WINDOW AUTO STOP
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT) SHELF WITH REAR LOUDSPEAKER GRILLE
ON-BOARD COMPUTER NO COMPUTER
COURTESY LAMP RE DOORS CONT EN + - + FR RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIV + PASS SIDE (W / O NOTICE)
STORAGE (DRIVING POSITION) OPEN UNDER CONSOLE + FR SEAT SETTING
RADIO RECEIVER NO RADIO
REFRIGERATION WITHOUT AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
HEIGHT CONTROL DRIVER'S SEAT PARR + FR DRV ADJ HEIGHT
INTERIOR REAR VIEW MIRROR DAY-NIGHT REAR INNER MIRROR
RHEOSTAT RHEOSTAT
AIR CON. / TEMPERATURE CONTROL WITHOUT CONTROL AIRCON / TEMP
STORAGE (OTHERS) FRONT SEAT STORAGE BOXES IN BOOT + 2
CARPET COVER W / O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
CARPET DILOURS CARPET F330
LIGHTING TIMER ADJUSTABLE TIMER
SWITCH CODED IGNITION
COOLANT LEVEL WARNING LAMP WATER LEVEL WARNING
CONTROL MALFUNCTION WARNING LAMP ADB Functioning ALARM
EQUALISER AMPLIFIER AMPLIFIER WITHOUT EQUALISER
LOCKING CONTROL CENTRAL LOCKING DEAD
STEERING WHEEL RUBBER STEERING WHEEL, 4 BRANCH
Electrical
ALTERNATOR ALTERNATOR 90 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 4
SPECIAL LIGHTING DAYLIGHT RUNNING LIGHTS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITH FIRST AID BOX
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE EFFECTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 H / F 1 MAIN KEY PLIP 1 SECON
SURFACE CONDITIONS GOOD GROUND
SPEED MONITORING CHECK WITHOUT SPEED
EMERGENCY WARNING TRIANGLE WARNING TRIANGLE conditionning
Re: FAO Ares
:roll:
Ares
Re: FAO Ares
Post by Ares »
Trem,my man,thank you very much for this.
respect bro :D :D :D
