With the engine at tickover, pump the brake pedal, after several times the pedal goes solid (like there's no servo assistance) keep the pressure on and the pedal slowly sinks down a bit as the VAC recovers.
Mine does this, and I am beginning to think the VAC pump is not quite running as it should, I'm also getting variable performance at times and this will also point to the VAC pump not operating the Turbo wastegate properly.
As I remember, with a petrol engine you can pump the brakes as many times as you want with the engine running and the pedal won't go solid on you.
See if you can try it and let me know?
Cheers
