Brake contact signal
rwb
Post by rwb »
Peugeot Planet 2000 wrote:Intermittent fault. Brake contact signal. Coherence of the 2 brake switches or main switch signal incorrect.
Discuss. :cheesy:
Re: Brake contact signal
Since you haven't got cruise, just ignore it.
(The 2 swithces are supposed to operate a little apart and in the right order as you press and release the pedal).
You can monitor it somewhere with PP2000, 'Driving Information', maybe?
rwb
Post by rwb »
Doggy wrote:...just ignore it
I shall continue to apply this strategy gladly :D
Doggy wrote:You can monitor it somewhere with PP2000, 'Driving Information', maybe?
I found that, and it was correct about whether or not the brake pedal is pressed.
Ta :D
I have the same code when I had the remote reprogrammed. No idea what it is since cruise works and brakes brake :D
I did have a faulty cruise a few years ago when the cruise switch fell out at the brake pedal, so it could be a remnant of that...
Oh ffs :( So you've got both the wiring and the switch but no cruise, while I have neither wiring nor switch but a stalk I want to fit but don't want to run wires across the engine bay :roll: It's there at the ecu but where it goes then is anybody's guess :frown:
If the Yoyo ever comes back from the garage I've got a wire locator to try out...
