hi all,
anyone had or worked on ford Ka? them egg shaped things ?
been trying to get the horn/air bag off, as theres a anoying scraping scratching noise,
any ideas,? theres no torques screws /bolts or slots.
ford?
Re: ford?
Never done one, but seen this....
http://www.talkford.com/topic/178532-removing-airbag/
http://www.fk-oc.com/e107_plugins/forum ... .php?66370
Re: ford?
cheers jasper5.
alittle bit of spray grease sorted it,
no more anoying clock spring or what ever its called,
next job ford ka alternator removal,
who decided to throw an old ford anglia engine in these things,
Re: ford?
They are the same basic block as the old 'Kent'? engines, push-rods and alllozz wrote:who decided to throw an old ford anglia engine in these things,![]()
I've heard that the KA/Fiesta Gearbox is still the very same unit that was used in the late 70's, even the machine that makes most of it is still the same - it looks exactly as you'd imagine a machine from the 70's to look. Still if it works then......
