Hi all
Can anyone have a quick look and find the refrigerant gas capacity for my 2003 110 hdi rapier estate (vin is 81569371)
The compressor is a Sanden SD7V16. I know the gas is R134a but I cant find the correct quantity to put in. I have just replaced my condensor as it had rotted out in the bottom corner as is usual with these. I have lost the sticky label that's usually under the bonnet with the refrigerant details and I have an air con engineer at work who will regas it if I can find the capacity. We have pressure tested with nitrogen and all is now ok
I looked on service box but I couldn't track it down :{
Air con gas capacity?
Re: Air con gas capacity?
Did you read: viewtopic.php?f=10&t=7606
(Which inludes "His book said 750g R134a").
IIRC I found several tables online which said slightly less, but that worked fine for the 3 and a bit more years I had the car.
Also note the bit abiut having to force the clutch on the first time, you may not have to, but it could save you hours of guessing.
Thanks doggy
620 grms was put into my system from empty.a 2003 110 SE estate.Its working lovely since I had it done a few months ago.
2003 Hdi Est SE
