Just a quick question
What size of sockets are required for the front and rear hubs on a hdi 406
Hub bolt sizes
Re: Hub bolt sizes
Front's definitely 35mm. Not sure on the back.
Re: Hub bolt sizes
Back is 40mm. You will need to put a long bar on the socket to undo it though..!!
Re: Hub bolt sizes
Just ordered myself a 40mm but are you sure the front bolt is 35mm I thought someone in the past said 36mm
