Got my Lexia/PP2000 setup through today, and merrily went through the install procedure, etc, then plugged it into the car to find... it only talks to the engine ECU. Everything else (BSI, ABS, etc) comes up as 'ECU has not replied'. Tried the global test and trying to go in to the individual units - nope!
Tried several versions of PP, all with absolutely no luck - it'll read the engine ECU fine, clear codes, all you could possibly want from that - just absolutely bugger all from anything else, which is somewhat annoying, as the other things are the parts I want to interrogate.
Any ideas? And yep, I selected 406R and put the right build code in. Adapter is from a UK seller, firmware 4.2.2 - tried 4.2.4 as well, no joy.
