I downlaoded BB flashback yesterday - it'll run on my desktop m/c but not the laptop, (suspect because it's not got internet access).
Don't fancy repeating the process more than once more, hence the desire not to re-invent this particular wheel
TIA
Not really, I'm trying to find which parameter(s) are slow to respond on initial pick up, to determine if I'm looking for an issue with fuel, boost or something else. Wanted to record all the live data from a few runs, then look at the dynamic behaviour.......rwb wrote:Are screenshots not sufficient?
Thanks for the recommendation - I might try that tomorrow.I have used this and found it wholly adequate:
http://camstudio.org/
That's interesting and potentially far more useful, particularly if it logs parameters regardless of whether they're on the current screen.mjb wrote:PP2000 does have a logging facility whereby it'll save an XML file somewhere (deep within its directory structure, find it using a search for files modified in the last ... mins) with a page's readings in two second intervals. It's one of the icons at the bottom of the screen iirc. Can't be any more specific because I haven't done it in about 3 years
Thanks for the recommendation - I'll check that out too.oldskoolskool wrote:I used autoscreenrecorder when I wanted to see mi injector correction values, downloaded from the following link.
http://download.cnet.com/AutoScreenReco ... 80978.html
