Hey.
Do not know if this is a fault, or that's how it should be.
2 Vents are working on low speed as soon as turning the key ACC mode - Even when the engine is cold !
Once turning the key to ON, the vents shut down.
Is that right ?
What is needed to check? BITRON unit ? 3 relays on the front car ?
I note that once the engine is working, they activated only when engine temperature rises above 92 degrees approximately.
Ariel.
Peugeot 406 D8 1999 1.9 TD manual.
406 D8 SRTD - Vents are working at ACC key mode
Re: 406 D8 SRTD - Vents are working at ACC key mode
Someone, please ?!
