I HAVE removed bolt in centre of steering is that all thats holding it on?
it is more stubborn than last time .
STEERING WHEEL REMOVAL
HDI RAPIER BLUE D9 2001
- oldskoolskool
Re: STEERING WHEEL REMOVAL
Yep, just wiggle it around a bit and pull.
2003 - Aegean Blue - 2.2L HDi - S
Nicowico pipes, de-fapped, de-egr, K&N, pipecraft stainless exhaust, Re-map, paddle clutch & SMF, Nakamichi cd400, 5000k hid's & led's
Styled by piniferina, modified with shopping trolleys and car doors.
thats a bit understated .....pull like f*ck whilst wiggling hard,then watch you dont smack yourself in the face when it finally gives inoldskoolskool wrote:Yep, just wiggle it around a bit and pull.
Give the wheel a whack top and bottom, then pull as straight as you can, but also mind your nose...
Good lord Turn the nut on a few turns, then it can't come off and break your nose.
Takes all the fun/suspense out of it if you do that tho Steve............................steve_earwig wrote:Good lord Turn the nut on a few turns, then it can't come off and break your nose.
^this. Much easier to pull hard if you're confident that you'll keep your face in one piecesteve_earwig wrote:Good lord Turn the nut on a few turns, then it can't come off and break your nose.
