fuel filter change put anti pollution fault on
I all just changed my fuel filter & seal as as usual the filter pot was weeping a tad from the top seal which it seams to do every few months or so but its not the 1st time so no trouble. But what was a bother is it over ran a few times after I switched it off just for a few seconds BUT it put my engine light on & anti pollution fault on the centre display above the stereo. I took it round the block & it switched off fine & is now spot on but still anti pollution warning & engine fault sign on the clocks. Or will it be a case of when I get my pp2000 sorted "haha fpmsl" will have to switch it off ????????
2.0hdi lx 51 plate 90bhp chassis no.VF38BRHYF81371125
Re: fuel filter change put anti pollution fault on
You might find it clears itself Brian after two or three trouble free start ups.
Yeah it's spot on just the daft anti pollution warning. Then again how or where is the annoying warning buzzer located as my hammer would love a few words with it. Has any1 ever removed the pig plz
'the daft anti pollution warning' is just pugspeak for any engine ecu related fault.
The only answer, (if you prefer not to ignore it), is to get it diagnosed, so you know what it's moaning about.
It's the beeping that's the annoying thing otherwise it will wait tbh
Started the car this morning & light off running spot on. I think the pot may still be weeping a tad but can't be arsed lol
Was probably a low rail pressure fault when you first started up after changing the filter, same thing happens if you ever run out of fuel too.
