I was working on my neighbours X type yesterday fixing a drivers door that did not open from the outside, it turned out to be the adjustment in the rod that connects the handle with the latch mechanism. But i noticed the car also had an EML light on and after reading the codes it brought up a MAF sensor code.
Looking at the MAF sensor someone had damaged the 4th wire and insted of soldering it back together they wrapped the copper wire around and put a bit of tape over it, the tape got loose and the problems started, that was fixed, but i also noticed where the air intake goes into the turbo was very loose, removing the pipe the rubber seal between the pipe and turbo was in shite, what is the name of this bit of rubber seal? Its the 2.0d engine.
Jag/Ford Diesel Question
