Oil leak!
Joeboy
Oil leak!
Post by Joeboy »
Hey guys seems I have a leak on my oil return pipe from my turbo on my 2.0 petrol. Is this an easy fix?Image
Sent from my iPhone using Tapatalk
madmadmax
Re: Oil leak!
Post by madmadmax »
put a jubilee clip on it
Joeboy
Re: Oil leak!
Post by Joeboy »
It's the metal tube going into the block. That wouldn't help I don't think.
dirtydirtydiesel
Re: Oil leak!
Post by dirtydirtydiesel »
It's not a high pressure oil line or it would be a banjo type union, if it really bothers you you could try pulling it out cleaning it up & the hole then refiting it with a smear of loctite 638 high strength retainer preferably but you could use some j.b weld or araldite or even some silcone sealent (just not sure how long the last one would last). but I have used it successfully on race engines in all sort's of places & it's been very reliable :cheesy: .
The loctite can be quite expensive (but I use it at work every day), araldite is also very good on engines as long as you make sure the area is spotlessly clean :roll:,
B.T.B.H, it dosn't look that wet with oil I'd be tempted to just leave well alone.
All the best DDD.
Joeboy
Re: Oil leak!
Post by Joeboy »
Thanks for the great advice. I'm going to try some loctite.
