Finally 1.6 110 hdi Remapped!
OllieNZ
Post by OllieNZ »
After much searching I finally found someone to come and sort the dpf on my 307 1.6 110 hdi. I like to give a big thanks to David from Omg Tuning the service was excellent and David didn't leave until he was 100% satisfied with his work.
The map itself is superb. He took into consideration the age, milage and condition of the car before deciding how much he could safely tweak it. It's very smooth and when driven sensibly you notice the lower throttle percentage required especially when sitting at a constant speed (I wish I'd done a live capture with pp2000 so I could give a real terms comparison) and when you put your foot down it goes for it no peaks just smooth power from down low all the way to redline.
Very very happy with both the service and the map.
gumby6371
Re: Finally 1.6 110 hdi Remapped!
Post by gumby6371 »
Glad to hear that as my other halfs car is running like a bag of sh*te at the moment while I get round to cleaning the DPF.
How did he flash the ECU in the end? I doubt I could get anyone local to me to bench flash an ECU on my drive.
OllieNZ
Post by OllieNZ »
He did it via the obd port. He said it's down to the equipment and software used. He did bring a bench with him incase anything went wrong.
Give him a try. He came out from London to Oxford same day as he wasn't busy. I called him at nine and he was with me just after eleven. He also has branches up and down the country.
