Its an '02 registered 406 2.2Hdi Estate - the GLX version in ' China Blue ' .......
Put it on PP2000 earlier and here is the rundown.
Airbag fault - trigger 1 and 2 drivers side, diesel additive low, EGR valve flow is wrong and turbo pressure too high, swirl flow diaphragm doesn't move. Couple of other minor faults , noisy pulley etc but nothing to worry about. I'll send the Comms unit off to the chap that John used while I'm attempting the de-fap and EGR blank and simultaneous swirl diaphragm.
Lastly, the brake pedal is really hard when you first brake but after about a second the pedal starts to give a bit and the brakes work really well - would this point to a vacuum leak?
Pictures and subsequent updates too follow
Kelv.
