alarm fault
ipubudu
alarm fault
Post by ipubudu »
hi guys
i have 406 sedan executive 2.0 16v (petrol). when i lock the doors with remote, anti thief alarm does not armed. there are couple of ultra sonic sensors inside car, i try with window down, lock by remote, wait for 2-3 min and wave my hand inside the car. but alarm not work. please help to fix this problem. :(
where is the alarm ECU Located in 406 s?
fattail95
Re: alarm fault
Post by fattail95 »
Hi mate,
Just answered exactly the same question! These are the images from ServiceBox.
Semi-mux:
Fully-mux:
Hope that helps mate :)
Benjamin
Re: alarm fault
Isn't there a button between the front seats which disables the sonic sensors.
Re: alarm fault
Do you press the lock button twice?
ipubudu
Re: alarm fault
Post by ipubudu »
there is a button near the hand break lever for interior alarm control. i press it as user manual, but i can't arm the alarm. :!:
I'm not sure, i press the key-button twice. if i did so how can i correct that?
markw
Re: alarm fault
Post by markw »
Sorry if you already know this, but you don't arm the system from that switch. It's used to disarm the interior sensors before leaving the car (in case pets (or the kids :oops: ) are left inside)
To do this, you switch off ignition and before a 45 second window has elapsed, press and hold the button down until the led goes solid red. Leave and lock/arm the car as normal and the protection will be on the openings only, not inside.
ipubudu
Re: alarm fault
Post by ipubudu »
markw wrote:Sorry if you already know this, but you don't arm the system from that switch. It's used to disarm the interior sensors before leaving the car (in case pets (or the kids :oops: ) are left inside)
thanks mark
ipubudu
Re: alarm fault
Post by ipubudu »
anybody knows the part number for alarm control module of 406 executive saloon( yr 2000) please?
Re: alarm fault
GingerMagic wrote:Do you press the lock button twice?
I believe one press of the lock button activates the deadlocks, 2 presses disables the deadlocks but activates the alarm...
I may be wrong, try it with the window down and opening drivers door from the inside handle.
