not 406 related.
not 406 related.
anyideas.
the dash clocks on my 207 are faulty..BBA remain say theres a fault with the processor on these. (stupid modern car's :(
thinking of just Buying a new set -rather than sending them for repair.
only thing is the Mileage will be 000000 on the new set.. :?
will that adjust or wouid ineed a company to correct the mileage.?
Re: not 406 related.
I'm not really sure, I think it should on a 406 so the 207 probably will. Fit it and see what happens? Or you could ask when you buy it.
Thanks steve.
Iasked at the main dealer's but they where more interested in having them fitted by them selves so ididnt get an answer,
the price was shocking so ididnt take them up on the offer.
Igot a brandnew set off ebay. £49 from a Peugeot dealer..so igot lucky.
(just got to wait & see what happens when iswap them over. :D
I'got reply back from the Dealer,
The car has to go in for software to be added /updated to the new clock's.
So no win..there. :(
I wonder what, something PP can do probably. Or maybe they're just trying to get you in so they can charge you for doing basically eff all.
Options:
Clocks start off at 00000, oh dear, if you punt the car on give the new owners the old faulty clocks and tell them why.
Clocks take mileage from BSI, the sun comes out from behind a cloud, angels sing and a politician tells the truth for once.
Clocks explode, the police turn up and taser your arse.
Cheers steve,
that's what iwas sort of thinking too, /BSi shouid swap/share- info to the clocks'
when the clocks arrive..iwill fit them in and see what happen's.
Sorted. :D you was right steve.
fitted them,& then removed them after seeing the mileage.
then irealised it shows the SERVICE miles first.(doh) :oops:
Theres no info held on the clocks.,
looks like theres a special (pug) tool anti-tamper thing needed for these too, (soon sorted with a hot screwdriver)
Just got to check the speedo reading with Sat-nav next..and Re-calibrate it (two -spoon's ) if needed.
99% accurate-with shat nav reading. (didn't need 2 spoon's :cheesy: )
so much for needing maindealer too.. set them.. :lol:
