Window anti pinch feature information?
Rob5464
Post by Rob5464 »
I have been looking for information but so far nothing has come up. I have bought some Heko wind deflectors, but the anti pinch feature is stopping the window from fully closing.
I tried disconnecting the battery to re-calibrate the window, but to no joy. Ideally I would just like to unplug the sensor or ECU. But I don't know where either of these are or what they look like.
Current: 406 HDI, Dead 306 HDI. Previous: Trooper, Range Rover, Shogun, Hilux, 206
Re: Window anti pinch feature information?
I think it's part of the motor itself.
Try lubricating the window rubbers with silicone maintenance spray, see if that helps.
Press and hold up the ^ Button,until you hear it click,
ihad same problem with our 207. that's how isorted it,worth a try,
grasmere59
Post by grasmere59 »
I tried the same wind deflectors on mine and it did the same although worse on the drivers side,i tried everything and gave up on the drivers side and slung it in a tizzy but the passenger side is still on the car :oops:
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Rob5464
Post by Rob5464 »
I have tried but it doesn't want to go up, I will try lubing the seals.
Failing that, if the mechanism is part of the motor I will see if the motor on my 306 fits.
I could try trim the rubber seal, so its not so tight on the glass. But if it doesn't work I will need to buy a new seal. As water will get in without the deflector.
