Key Fob Issues
gumby6371
Key Fob Issues
Post by gumby6371 »
Morning all,
I've been having some issues with locking/unlocking with the key fob lately, sometimes it will and sometimes it wont. If I take the fob apart and press the micro switches directly it seems to work fine so I'm guessing the after market fob the previous owner acquired is starting to ware and needs changing. Thats no real issue in itself but strangely enough I can now only start the car if I insert the key button side down, the other way up it won't turn and the steering lock stays on. I find it difficult to believe the transponder is too far away if the key is button side up, can they fail with time?? is it likely the transponder ring has moved??
As I only have 1 key I'm a bit nervy that it will stop working all together and need to get it sorted sooner rather than later.
All suggestions gratefully recieved as always especially the FOC fixes!!
Re: Key Fob Issues
gumby6371 wrote:the other way up it won't turn and the steering lock stays on
So that's not the transponder then, that immobilises the engine and it just cranks and cranks, if the key itself isn't not turning then they key is damaged/worn (or the lock is but I don't like to think about that)
When you say after-market, what exactly have you got there?
gumby6371
Re: Key Fob Issues
Post by gumby6371 »
When I say after market its an eBay copy of the original
Re: Key Fob Issues
So with the original's guts in it? I think you have two problems there, probably both due to the "after-market" key fob. I'd say get another one but cutting it will be difficult if it's too worn.
