PEUGEOT PLANNET 2000 SOFTWARE
mundy1989
Post by mundy1989 »
hello everyone, I have purchased a copy of peugeot plannet from ebay and the guy has sent me a link to download plannet from, ive downloaded the software and installed it but csnt seem to get it to activate! Does snyone have a decent copy of it or shed any light on what I need to do? Cheers
Re: PEUGEOT PLANNET 2000 SOFTWARE
Hi mate, check this out :arrowd:
https://www.youtube.com/watch?v=XUIZ5sZmbpI
You need to create a file on the C/ drive called ' version ' using notebook - not sure why this is important though...
There should be a file called 'KeyGen' and this will generate the code required to activate Planet.
Follow the guide and you should be fine, at least you can pause the YouTube clip while you enter lots of activation codes trying to get it right.. :wink:
MixMan
Post by MixMan »
Planet can be a pain to activate.
It will eventually, just keep entering new codes from the keygen.
Think my record was 23 attempts before it finally activated.
I have no idea what the problem is, unless it needs a certain sequence to recognise the code.
Currently frustrated by: 2002 2.2HDi Executive Saloon
gray
Post by gray »
once you have the pp2000 loaded, is it necessary to update the program to the newest version? does it add features to the program?
seems like the program doesnt have a lot of live data with regard to watching sensors?
Gray
2000 D9 2.0 litre RFV saloon
dirtydirtydiesel
Post by dirtydirtydiesel »
WHAT EVER YOU DO! be very very carefull with updates remember that this is a bootleg copy of dealer software, I had loads of problems :roll:
As have others, it is well worth it in the end, there is lot's of info on this site with regards to this & you will need to trawl though it all to sort
out the info from dis info, just as I did :wink: good luck DDD.
Liliflower
Post by Liliflower »
what the version of your pp2000
anyone succeeded in installing it on Win7
http://eobd2.bcz.com/2015/01/28/how-to- ... windows-7/
get a good document, any ideas
