And also that the main "big" button on my remote fell out (the acutal switch bit)
To cut a long story short I'm having a new kitchen fitted and found the button switch thingy
So I popped it into the remote and bingo - when pressed the car unlocked, to I pressed it again and was about to hit the deadlock button when I had a nasty thought
Once the deadlock button was pressed would the car re start or would I need to get the wires out on the immobilier and pray
Suffice to say I've started the car and then just locked it with the key in the lock.
But does anyone know what would happen if I decided to use the remote? It is true to say that when I lock the car I leave the key turned until I hear the "thunk" of the dead locks kick in, but when you use the remote to lock the car the hazzard lights flash too - which doesn't happen when you use the key.
Anyone know? Cos I'd hate to stuff things up when I've just had the 406 serviced (£400 quid: 4xTyres, Rear brake shoes, calipers, PAS fix etc etc). She needs to last until June!
Cheers
Mike
