think I have dropped a clanger
Hi all I have just purchased some eoyls of my friend who is scrapping his c8 its a 2003 one is this ok to use in my 2002 2.2 hdi 406 or have I dropped a clanger many thanks paul
Re: think I have dropped a clanger
As far as I know the 8 valve Hdi doesn't have a DPF, at least none of these I have come across have, but the eolys should be fine for your 2.2.
I can't see why you think you've cocked up, it'll be the same stuff but you will need PP to reset the counters.
- jonsowman
Around build code 9492-9494 the fluid changed. I can't remember the details offhand but better make triple sure before you fill it with the wrong stuff and cause damage!
Hi the codes by the door hinge are 0861289 20104 eged 2204 if that is any help thanks again
- jonsowman
8612 would be the build code there, but that's 7th June 2000, and you said yours was a 2002, which seems unlikely to me?
It's a nice colour though...
It's taken me a while to find it...
Looks like the problem may be if the 406 was built before this date but the C8 was built after. We really need build codes for both (or chassis numbers...)
I learn something new every day. And then forget it, it would appearThere are two types of additive EOLYS :
EOLYS DPX 42 for vehicles manufactured before 11/2002 (Up to build code 9491); The additive reservoir click-on connectors and the drum caps EOLYS DPX 42 are white
EOLYS 176 for vehicles manufactured from November 2002 build code : (From 9492) ; The additive reservoir click-on connectors and the EOLYS 176 drum caps are green
Hi its a 51 plate but registered in 2002 if that helps thanks paul ps if my friend has still got the motor is the code in the same place as mine thanks Paul
Hi all again got the chassis number off my friends old car it is vf7ebrhtb13052758 hope this helps Paul
Ah bollocks, it's after the changeAS RPO No 09583 U9 1 0497
Ah well, at least someone knew what they were talking about, I'd have had you bugger your car up by now...
