Rear windows electric conversion
Imissit
Post by Imissit »
How hard is it to convert my rear windows from manual to electric? And is the wiring usually allready there? :)
Re: Rear windows electric conversion
Is your car a D8 or D9?
It's certainly do-able, I fitted electric rear windows and electric wing mirrors to my first 406 (D8 LX) but be prepared with the soldering iron & heatshrink ;)
The biggest pain was getting additional wires through the door grommets; you'll need to do this if you want to control the rears from the drivers window controls.
Imissit
Post by Imissit »
mine's a D9 : ) Luckily i allready have electric mirrors. Is there a possibility that the wiring for the rear doors is allready there?
You might be in luck in that case :)
I've never worked on a D9 so I can't talk from experience, you may have to get the windows enabled in the BSI as well.
Existing wires seem to be a bit hit or miss, your best bet is to have a door card off and see if it has spare wires.
Imissit
Post by Imissit »
OK ill have a look tomorrow :) atleast i have pp2k :)
PeterN
Post by PeterN »
If the car is a popular colour it might be worth changing the doors, there are plenty about on ebay.
