P0571 fault code
P0571 fault code
Retro fitted cruise control to my 2000 406 estate, all switches were there, made my own master switch, done all multi meter checks, all fine, all switches replaced with new on pedals, stalk fitted and checked and functioning correctly, activated cruise control through pp2000, all is well barring the p0571 fault code, checked everything and all looks well, brake lights working, just cruise control switch permanently active.l so cruise control wont work. Where do I start for repairs?
Re: P0571 fault code
Here maybe
Or do you mean the stalk?Ady1985 wrote:made my own master switch....cruise control switch permanently active
No, stalk is there, the master switch next to the obd port, made my own, all works well, tried everything, pp2000 saying cruise control switch (on brake pedal) is permanently active, so the fault lies somewhere around pedals
Try disconnecting it and then try shorting it? I don't know if it's the same on a semi-mux but mine read active when I'd put the wire in the wrong hole so it was permanently open circuit.
