Peugeot 405 Exhaust System
If anyone is still driving one of these bad boys, then they might have use for an exhaust. Removed from a '96 1.9 TD saloon, but I wouldn't be surprised if it fitted other models.
Nearly new, front section approx. 15k use, middle and back box approx. 3k. Has been stored down the side of my garage for a number of years so is scruffy in appearance. £25.
Peugeot 306 GTI-6 Front Callipers
Good used condition, can be used as an upgrade on other PSA vehicles.
DW10/HDI Con Rods
Set of DW10 con rods (can also be used to upgrade an XUD). £40.
Peugeot 405 Steering Rack Boots
Original OE steering rack boots, part numbers 4066.30 and 406.37. £20.
K14 Turbo from a Peugeot 405 TD
Blows a bit of oil and sounds like a police siren, only good for a rebuild. £15.
Bosch AS3 Injection Pump
From a Peugeot 406, car was running fine up until it was removed as it's leaking from the input shaft and throttle arms seals. Has been run on 80/20 veg/misfuel blends for approximately 50k. I have a rebuild kit for it which can be added at extra cost. Not suitable as a replacement for the mechanical VP20 as found on earlier models, 306 etc. £40.
