Opie Oils are happy to announce the arrival of Pentosin which has been added to the 76 top quality brands Opie has to offer. To see all the brands please click HERE >>>
Opie Oils sell only a few Pentosin products but may add more in the future. Here is what Opie Oils have to offer;
Pentosin Brake Fluid
With Pentosin Brake Fluid under the hood, drivers enjoy increased safety and reliability.
Pentosin Super DOT 4 is a brake fluid of superior quality for universal use in modern brake systems and ideal for vehicles with ABS systems.
Pentosin DOT 4 LV is a special brake fluid of highest DOT 4 performance levels and extremely low viscosity at cold temperatures.
Pentosin Super DOT 4 PLUS is a exceptionally formulated brake fluid with significantly higher boiling and wet boiling point.
Pentosin Racing Brake Fluid is a special formulated thermally extremely stable fluid of highest DOT 4 level.
Pentosin Gear Oils
Pentosin is currently leading the development of twin clutch transmission fluid. After all, they are the recognized leader in hydraulic fluid and transmission fluid technology.
Pentosin FFL-Racing DCTF Nissan GT-R R35 approved has been exclusively developed for the application in the new Nissan GT-R R35 double clutch transmission.
Pentosin FFL-4 Double Clutch meets BMW EU: 83 22 2 148 578 & BMW EU: 83 22 2 148 579 spec
Pentosin FFL-3 Double Clutch meets Porsche 0000 043020 spec
Pentosin FFL-2 Double Clutch meets the VW TL 521 82 spec
Pentosin ATF1 is a DEXRON III and DC ATF +4
Pentosin MTF 2 this is a GL-4 oil
Pentosin SAE 75w-80 meets the API GL-5 oil
Pentosin Hydraulic Fluid
Ideal for cold weather climates, Pentosin Hydraulic Fluids are synthetic-based and have an operating temperature range from -40°F (-40°C) to +275°F (+135°C).
Pentosin CHF 202 has been approved by Ford, GM, Opel, Porsche, Volvo & VW
Pentosin CHF 11S has been approved by these leading car manufactures: Bentley, BMW, Fendt, Ford, Daimler, GM, Opel, Mercedes Benz & Porsche.
That's it from us today, but if you have any questions or need any advice then we can help. You can call us Monday - Friday 8.30am to 5.30pm on 01209 202944, email us at [email protected] or just ask us here.
Cheers
- Oilman
