Backplates
grasmere59
Backplates
Post by grasmere59 »
I'm going to give the whole braking system an overhaul soon and I know the rear backplates were rough a couple of years ago,how much do they run at for a pair nowadays?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
dirtydirtydiesel
Re: Backplates
Post by dirtydirtydiesel »
Back in 2012 they were £93.00 + vat each & your need to replace the rear hub / wheelbearing assembly while your at it :roll:
You'll be doing the disc's pads & brake shoes, handbrake cable oh & maybe a caliper overhaul / replacement :(
Probably £500 ish all told :shock:
grasmere59
Re: Backplates
I've got the hubs,discs,pads,shoes etc (all oem) it's just the backplates i need to get and i can get started.
Re: Backplates
They're now almost a ton each from Pug :shock: (I'm surprised they're not NLS yet...). They do come up 2nd hand on the bay but rarely these days (the last few have been drum brake ones too) or you could try contacting Ade1122 on the bay or via the coupe club. I think he charges about 25 quid each.
grasmere59
Re: Backplates
Might have to bite the bullet then and get new ones :( .To be honest over the last 3 years the car's cost me very little to run so i might treat it to a new set and get all the brakes up to scratch ready for winter.
Re: Backplates
It seems a bit excessive to me, are your old ones really that bad? If they're just a bit flaky you could have them acid dipped and galvanised...
fattail95
Re: Backplates
Post by fattail95 »
I'm just in the process of re-doing my brakes at the moment, I got a pair of back plates from Ade for £40 delivered, and then had them shot blasted and powder coated for £20 each and came back like new! All in it was £80 for the pair after painting, less than 1 genuine one from Pug and I know these ones are properly protected. I've also got a spare set that I'm gonna get powder coated in case these ones ever rot :lol:
I also had the calipers rebuild and painted while they were off, complete remanufacture including seals etc so they're now in new condition
Should be a good improvement when I'm finished, the brakes were not in great condition beforehand...
annie
Re: Backplates
Post by annie »
that is a great job for that price..they look like new
omega
Re: Backplates
Post by omega »
ive got a good used pair will have to find them now
grasmere59
Re: Backplates
Give me a shout if you find them :)
ridgie74
Re: Backplates
Post by ridgie74 »
I did a bit of googling and see the backplates are made by klokkerholm for peugeot. they call it a splash panel.
p/n left: k5536877 p/n right: k5536878 £36 pounds each.
I gave http://www.carz2.co.uk a call on 01684 565 882 and she is apparently ordering them from Denmark, should take 3 weeks, then I shall be contacted to deal with payment. (They seem to work on a 3 week ordering cycle)
Anyone used this website? I will wait and see if I get a call back. fingers crossed or my 406 is toast.
grasmere59
Re: Backplates
Keep us posted on how you getr on :)
ridgie74
Re: Backplates
Post by ridgie74 »
will do!
jasper5
Re: Backplates
Post by jasper5 »
Just a note about another car with a similar problem to the 406 that people might be interested in....
Yesterday I did a Mercedes SLK with a handbrake fault...the handbrake shoe holding pins (they are little coil springs on these that slot through the backplate) had pulled through the backplate due to the backplate having corroded away where the pins go through!!
Note the familiar problem :D
It needed the linkages freeing off and new shoes fitting...fitting those springs through the backplate is VERY tricky!!
I used penny washers with a normal brake shoe holding pin round clip fitted in reverse to fasten the springs through the backplate.
Re: Backplates
On a Merc? I can't believe it :roll:
ridgie74 wrote:I did a bit of googling and see the backplates are made by klokkerholm for peugeot. they call it a splash panel.
They look like pattern parts to me but substantially cheaper than Pug so worth a shot I reckon. Please do keep us posted!
Oh looky, they do sills too :shock:
