Lots of useful 406 tech documents
Afternoon all,
I've collated several useful documents/guides that are relevant to the 406, hope they may be of some use to you.
https://www.dropbox.com/sh/3gptz2ov1t0n ... hKCoa?dl=0
Best Regards
Ben
Best Regards
Ben
150hp/330nm • Powerflow stainless exhaust • Kevlar clutch • Cat delete • EGR & Doser delete • Leather interior • Windows tinted • Cruise control • 5 dial cluster • Yatour bluetooth • Starfish alloys • Twin rear fogs
Re: Lots of useful ServiceBox documents
Aha, a downloading frenzy, well done sir
I've always wondered if it would be worth doing that but I'm not sure if that's the same stuff I have in the service box back-up repair manual, which is ok for the obvious stuff but bleedin' useless for anything tricky.
It certainly was! I hardly even touched the interior repair procedures and only made a small dent on the mechanicals. Lots of great information and the guides are nice and clear (for the most part) so I thought I'd made them a little more available.steve_earwig wrote:Aha, a downloading frenzy, well done sir
Well done, thanks for all the usefull information.I need to do crankshaft pulley and cam belt and it was interesting to read about cam shaft pully removal. Thanks again,
My pleasure - we've a good bunch of people on here, so I'm always happy to give back when I can. Frank's videos (PeugeotCitroen2CV on YouTube) are very good too:scoopeydiesel wrote:Well done, thanks for all the usefull information.I need to do crankshaft pulley and cam belt and it was interesting to read about cam shaft pully removal. Thanks again,
Cam belt:
https://www.youtube.com/watch?v=k66VwGX4uGk
Crank pulley:
https://www.youtube.com/watch?v=XDTot5kRAG0
Cracking effort Ben ..
It's worth adding that the torque values are displayed in deca newton-metres (referred to as either daN.m or m.daN). 1 deca newton-metre as you may have guessed is 10 newton-metres or 7.4 pounds-foot.
Thanks very much
Thank you!
I hate to be the one to urinate on your bonfires but isn't this a bit iffy? this is sharing information that should be purchased by those seeking it.
You are absolutely correct, however I don't believe PSA are going to see massive losses in profit over a few documents which are relevant to a car south of 12 years old. However if you wish to remove the post, I fully understand and will not dispute it.Welly wrote:I hate to be the one to urinate on your bonfires but isn't this a bit iffy? this is sharing information that should be purchased by those seeking it.
Best Regards
Ben
Re: Lots of useful S***b*** documents
I don't want to be a spoil sport but maybe a bit of discretion would be better?
Rather than shout this from the roof tops we could have a sticky to help members approach others via PM if they have technical info and are willing to lend it out to fellow forum members.
Re: Lots of useful 406 tech documents
You're not a spoil sport at all, on reflection a bit of discretion may have been a good idea -- I have edited the original post to reflect that.Welly wrote:I don't want to be a spoil sport but maybe a bit of discretion would be better?
I suspect some big corps would like nothing better than to take us to court for some small koppyright transgression, I'm sure Sony would for a start...fattail95 wrote:You are absolutely correct, however I don't believe PSA are going to see massive losses in profit over a few documents which are relevant to a car south of 12 years old. However if you wish to remove the post, I fully understand and will not dispute it.Welly wrote:I hate to be the one to urinate on your bonfires but isn't this a bit iffy? this is sharing information that should be purchased by those seeking it.
Best Regards
Ben
Although, in this case, it's probably not worth bothering as a lot of PSA tech docs are already out there so I don't think they're that bothered. There's quite a few on here already too.
I've changed the thread title anyway. Bomb it from space, only way to be sure etc.
