Resynching my key
bigknickers
Resynching my key
Post by bigknickers »
The previous owner changed the battery and told me the remote locking hasn't worked since.
I checked the remote battery which is fine at 3.2volts.
I have just done the procedure.......window open, battery disconnected for 5 mins, sidelights on etc etc.
I started the car and whilst the engine was running I was leaning in through the window and holding the large button on the fob for 20 secs.
The remote still don't work..............what can I do now?
Car is a 53plate 110bhp diesel 'S' estate
Re: Resynching my key
It probably needs PP2000 to get the BSI to 're-learn' the key(s)
You need the 4-digit PIN code from the card supplied with the car and someone with Planet
(Adding your location might get you an offer of help from someone nearby). :wink:
Try..
Putting the key in _ignition on and press the button on the plip.
bigknickers
thanks lads........I'm in Epsom
