Folding Memory/Heated Mirror Wiring Diagram
splitpin
Post by splitpin »
I'm looking for the wiring diagram for the Folding Heated/Memory Mirrors fitted to my 1999 D9 Executive Estate.
The one in the Haynes manual seems to be for the non-folding type. The plug listed is a 13pin White plug, whereas the one fitted to my car is a Black 16pin item.
The problem I have is that the heater doesn't work on the nearside mirror, but the HRW and offside mirror work fine.
I wanted to check that I'm getting power to the correct pin before I go breaking the glass to check behind it.
Many Thanks in advance,
Graham
Re: Folding Memory/Heated Mirror Wiring Diagram
You do know you're looking for numbers on the wires? I can give you a pin out but if you can't find pin 1 then it'll be pointless.
The heated mirror wires are labelled 8132 for the feed (or it could be 813 given how often the wiring diagrams are confused on right-hookers) and the earth is M6433 (or M6423 :roll: )
Let me know if you need further assississtance.
