floppy indicator stalk
mark1961
Post by mark1961 »
does anybody have a spare indicator stalk to sell for a 52 plate 110 hdi rapier estate please or can recommend a fix or even the best place to buy a replacement from as mine works ok but when indicating and turning right it cancels but goes straight to indicating left
all help is appreciated
thank you
trem1
Re: floppy indicator stalk
Post by trem1 »
Guy in Bradford fixes them for about £30
Sent from my K013 using Tapatalk
gumby6371
Post by gumby6371 »
http://www.qdi-ltd.co.uk/davcom2000.html
Did one myself and it was straight forward enough, took about an hour and a half including removal from car, comm unit repair and refitting. Worked perfectly and you're not waiting for it to be returned and it saves a few quid.
Locating the clips for the airbag is the biggest PITA first time around and winding the spring back in on the comm unit is a job not to be rushed.
Edit - an hour and a half does not include proper battery disconnect procedure then having a bite to eat while any charge dissipates near your airbag!!!!
You shouldn't have to touch the clock spring! :shock:
