Wanted bottom radhose bayonet fitting
shonkers
Post by shonkers »
Hi chaps bit of a long shot as title i,m after a bottom radiator hose the short one with 90 degree bend and the dreaded bayonet fitting, or if anyone could point me in the right direction, i registered with service box but now they're saying wrong password, and i know it,s the right one. It s a 2.1 td 97 estate cheers
Re: Wanted bottom radhose bayonet fitting
Bottom hose? Isn't that the one with the metal section that's made out of pure unobtanium??
The only short one is the top hose, which isn't NLS for a change.
#2 here
Good lord, only 15 quid too. What are the bets?
shonkers
Post by shonkers »
Hi mate the bottom hose i need is no1 on that diagram, the bayonet end goes into the rad and the other end attaches to the metal pipe with a jubilee clip, but on the diagram it looks like its part of the metal pipe, i,ve an idea i changed it before when i refurbed the rad which was in 2009 and i can't remember how i did it or where i got it from, or maybe it wasn't nfp then, sorry it,s been a while replying
Interesting! As far as we know, PSA never made just the end, rather you had to buy the whole thing (price one kidney). Now I'm wondering if they did indeed make just the end for a while, or maybe someone else made it, or maybe you found a pipe that fitted from another car (maybe not even PSA).
I think you need to pull that part off and see if you can find any codes on it :shock:
shonkers
Post by shonkers »
It's off and twas a pig to pull out of rad, can't remember seeing any codes but will have a look today, trying to think back i probably got a hose that fitted some where else on the car and chopped the end off to slip on the metal pipe then fix with jubilee clip,if i can figure out how to put pics up i will cheers mate
shonkers
Post by shonkers »
Thinking back i modified that hose by removing the factory fitting and trimming the hose to get rid of the hole, and this time i trimmed it again and fitted it to the metal pipe with a jubilee clip and put a new seal on the bayonet fitting, no leaks so it all looks good, cheers for your help steve earwig
