radiator fan
andyinkent
radiator fan
Post by andyinkent »
Evening. 1999 2.0 GLX petrol.
this afternoon started car at supermarket fan kicked in, and then wouldn't stop, got home disconnected battery , stopped, left it for rest of afternoon , reconnected
fan started again!!!
any clues plus tried to find fuse ....im sure its a simple fix however why on a Bank Holiday !!!!! :roll:
Re: radiator fan
Mornin' When you say fan I presume this is the early D9 setup with one fan, two resistors and 3 relays (behind a cover on the fan shroud). Could be one of the relays has collapsed, or the pressostat has gone haywire or the temperature sensor on the thermostat housing (there's 3 of them) has gone short circuit. This is probably (?) the fuse diagrams for your car http://www.peugeotlogic.com/fuses/fuses406/fuses8.htm I've had a look in Sedre but it's only showing me diagrams with 2 fans and no resistors :roll: An RPO and an actual engine code may help but I've tried quite a few.
andyinkent
Re: radiator fan
Thanks for your help ..... gives me a starting place
406Break
Re: radiator fan
Post by 406Break »
Had a similar issue :D
viewtopic.php?f=1&t=7659
I had to change the blue colored relay for the fan to stop
Peugeot 406 Break - 2.0L - 99kW - EW10J4/RFR - BVM5 - VF38ERFRE80937145
